Got a problem add small radius
904.1
Hi All.....
Below is the problem.....
Part attached....
Regards,
Lish
904.2 In reply to 904.1
Hi Lish - what is happening in this case is that there is an independent curve object (like a rectangle curve) that is on that exact same area.
That curve interferes with selection in this case - when you click there it is that separate curve object that gets selected, not the part of the solid.
Delete or hide that curve so that you can access the edges of the solid that are in the same spot as the curve.
Then once the edges are selected you can do a fillet of radius 0.3 .
Another shortcut in this case is to select that top face instead of the top 8 edge curves. When you select a face for filleting, all the sharp edges that belong to that face will be filleted, so in some cases it is easier to grab one face than a bunch of edges. I do expect to add additional edge chaining type tools in a future version.
Let me know if you still have problems with this one.
904.3 In reply to 904.2
Hi Michael....
Your tips work well....
Yes, I think add MoI with "Chain Selection" or "tangen selection" is good.
Regards,
Lish
904.4
Yes, there's a coupla scripts floating around here that lets you select open and closed curves. I usually run those first to hide any curves that are revealed to make sure I don't have any in the way when doing stuff like this...
-Will
904.5 In reply to 904.4
Those scripts are available on Petr's collection page here: http://kyticka.webzdarma.cz/3d/moi/
