Show Grid shortcut key
9038.1
What would be the command for Show Grid toggle under Grid Snap button?
Also, how do I find reference command for some UI buttons in the future?
9038.2 In reply to 9038.1
Hi Fubax,
For toggling the grid put in the following as the command part of a shortcut key:
script: /* Toggle show grid */ moi.grid.display = !moi.grid.display;
There are several listed here:
http://moi3d.com/3.0/docs/moi_command_reference11.htm#shortcutkeys
If one you need isn't listed there then just post a question about it. To look it up directly you can also look at the definition of the button in .htm files inside the UI subfolder of MoI's main installation.
9038.3 In reply to 9038.2
Thanks for the answer. I've also found some reference here http://moi.maxsm.net/api/
