moi3d for 3d printing
9028.1
Hello Everyone,
I am having a problem . when I design a model in Moi3d and open it in simplify 3d its not in correct scale. The model is ridiculously large what causes that . I export the model in STL Format .
any words of advice will greatly help .
Thank you ,
have a great day
Adan
9028.2 In reply to 9028.1
Hi Adan, .stl files don't have any way to mark what units the file is in. So probably simplify3d is making a guess and is ending up using a different unit system than what you actually used.
There may be an option in simplify3d where you can tell it what units were used in the .stl file, either that or you'll need to find out what units it is expecting and switch your unit system in MoI to that before exporting to .stl . Probably it's expecting either mm or inches.
9028.3 In reply to 9028.2
hello, Michael.
Thank for your fast response,
You are right under simplify 3d options
under model settings automatically scale was not selected .
Now it works
Thanks you so much for your support ,
Adan
