got a problem fill / close an area....
902.1
Hi Al...
I am playing with MoI, but I got a problem. I can easily close this are using sw.
Please see image below.....
Regards,
Lish
902.2 In reply to 902.1
Hi Lish, since that is a planar cut, you can use Construct / Planar to build a surface there and then join the pieces together.
But in MoI, the Planar command needs to have a fully closed outline.
So beginning with this model:
Draw a line snapped between these 2 ends:
Now select the line, and the edge of the surface to form a closed loop, then run Construct / Planar to build this:
You can now delete that line segment. Then select the 2 surfaces and use Edit / Join to glue them together into one single object.
It is a lot harder to fill non-planar holes, MoI does not have the full equivalent of the SolidWorks Fill command yet to fill more freeform areas, it is something that I do want to add in the future though.
902.3 In reply to 902.2
Thank`s Michael...
Now I have another question. How to close the end of the handle. I have tried using loft, but the result is not good.
See image & file below... Hope you have a tips for me...
Regards,
Lish
EDITED: 9 Sep 2007 by KHOLISH
902.4 In reply to 902.3
Hi Lish - I'd generally suggest using fillets for these areas as well. Instead of stopping your handle exactly at the area to cap, extend it further and have a plane as the cap, then use a fillet to round it.
For example:
For that one I didn't extend your shape, so it is a little shorter than you wanted. I selected your handle as an entire object, then ran Construct / Planar to fill in the planar holes, then selected the end face and did Construct / Fillet, using the Shape : G2 Blend option to get a more organic kind of blend shape there instead of an exact arc/circle shape.
It's generally harder to fill in an area like this with one single smooth surface instead - MoI does not currently have that tangent-preserving type of fill command like is available in SolidWorks, but it is something that I want to add in version 2.0 .
There are other methods you can use now, but they are quite a bit more tricky than using just the fillet like I showed above.
One option is to use Blend - Blend is one of the few tangent/curvature preserving kind of commands currently in MoI. Normally blend is used to make a smooth connecting piece between 2 surfaces, more like this:
However, you can also use it to seal off a hole where the hole is made up of 2 edges like you have in this case. To do this, select the 2 edges and run Blend, you can adjust the slider to control the amount of bulging. Also switch the Continuity: option to Curvature (G2) - that will generate this:
That's got a more fully rounded type shape like you seem to be looking for.
It is also possible to more directly model the rounded shape of the end by constructing a dome type shape at the end, that allows you more exact control over the shape. Here are some ideas for that approach - I drew this curve:
Then I ran Construct / Revolve / Rail revolve, and selected this edge as the rail curve, and drew the revolve axis as shown:
That creates this revolved cap surface:
That gives you a lot of control over the shape of the cap. But the cap meets up to the main handle in a sharp edge - to make that smooth you can either trim the cap back and then do a blend between the 2 edges, or join them together and then try to use a fillet to round out that area.
I hope this gives you some ideas, let me know if you need any more information on any of these techniques.
902.5 In reply to 902.4
Hi Michael...
Thank`s for the tips.
I like the blend command, easy & fast....!
Regards,
Lish
902.6 In reply to 902.5
The only problem with the blend method is that right now will only work if you have a hole made up of 2 edges, not if you have more.
But if you have only one single edge for a hole (like for example, the end of a cylinder or some tube-like surface that is made up of only one single surface instead of 2 halves), it is possible to break that edge into 2 edges by selecting it and using Edit/Trim with the "Add trim points" option.
Trim on an edge basically breaks it into smaller edge pieces.
