Hi all,
Well, didn't see the last two replies but thank you also for suggesting ;-)
As it is I have bought EstlCam and it looks reasonably straightforward for simple 3D structures (which is what I mainly need to mill), however, I have used most of the day today on trying to convert a very simple drawing in Moi3D (FYI attached) to something that I can import as a 2D file into Estlcam so as to make milling easier - 2D. The file quite simply are for holes in the CNC's spoilboard so that I can actually mill something ... And either Estlcam comes up with an error message like "empty file" or corrupted file ... or, if I try to convert an .ai file exported from MOI to DXF or SVG either it doesn't work or the drawing becomes HUGE (like many, many meters on each side), or there are no holes in it when it is imported in EstlCam (??). So I am actually - and unusually with MOI - pretty frustrated now as I don't seem to find a simple way to export 2D files into a format that Estlcam can handle.
So by posting here I hope one of you know how this can be done - it would be appreciated ;-)
Cheers & thanks,
Jesper
