Well, it's not easy to answer without more explain of your needing.
Designing a simple ring with MOI is very easy. You have to create a profile and revolve it.
But now, if you want add letters or shapes on a simple ring, you have to play with flow function.
If you want modulate the size of profile you can do it with lofting and sweeping functions with rails.
For printing rings, you can use an online 3D printing service like scupteo, shapeways...
For doing it, you upload your model (usually STL or OBJ files) on the website and doing choice for metal you want and its finishing (raw, polished, mirror polished, brushed...)
I use (and abuse) those services for pendants. I used it only one time to do a ring and result is pretty cool. It was long ago, and it was one of my first tests.
It wasn't with MOI and the result is little faceted because designed with a poly CAD software with no experience...
Those websites have great tools to test if your product would be well printed and have fast renderer to have a idea of the result. Fast render but not best render...
You have to know some constraints :
1/ Each metal, each finishing and each website could have different constraints, but usually it's near with minimum like "nothing less than 0.8 mm".
2/ 3D online printing services could be used for only one metal for each object. for exemple, no yellow and white gold together.
Now you can do pieces of different metals with those services, and next you can adjust their together but this is more difficult if you don't have jewellry tools.
3/ The process can result on a ring with little difference of size due to polishing, metal retractation...
For rings, usually, you can next adjust it +/- sizes. shops could do it easy, or a small tool about 15$ can help you.
4/ Verify the content of gold. I seen for 14k white gold, nickel usage. Nickel could be allergetic. Use better 18k gold or 14k yellow.
