Odd rotation behavior
8950.1
I am having a problem with this model in progress that I can't recall having previously (though it behaves the same way if I revert to MoI 3).
I can't seem to spin it easily. I want to be able to easily see the right side (right as in the posted view) but I can't simply spin the view so that this face will show in a more or less upright position.
It may be because I used the 'top' view to do the front elevation but I don't understand why this would make a difference in a 3d view.
Any thoughts?
cheers,
eric
8950.2 In reply to 8950.1
Duh!
Yes, that was the problem. After the posting I rotated the model so that it was in the right position relative to the ground plane and it works just fine.
I hope you did not waste any time with this.
cheers,
eric
8950.3 In reply to 8950.1
No problem eric, I'm glad you have solved it!
