Electronics Enclosure Designed in MoI - Ed Ferguson
Here's an electronic enclosure I designed in MoI and 3D printed in PLA plastic. MoI exports the model in STL format to feed a Slicer program, which in turn generates the G-Code to run the 3D printer.
The four-sided box was printed as a single piece. An aluminum bottom plate screws to the four tabs designed into the box. MoI was really helpful in that I could easily re-arrange the individual components to get everything to fit. The build plate on the 3D printer limited the maximum size of the box, and so I had to pack everything carefully.
In addition to the box, I printed a box lid and "nests" to hold the relays (red circuit boards) and the Wago AC power junction connector:
Only a few millimeters to spare on the Robo 3D printer build plate. The box is 7.6" (193mm) square. You can see the temporary support structures on the rear panel. Those are weak bridges so the printer can continue printing the solid wall over the top of openings. The temporary support structures are automatically created by the Slicer program and get knocked out when the print is finished, leaving holes for the cables and square power receptacle. :
You can see the clean square and round holes after the support structures were knocked out. Threaded brass inserts set into the plastic are used to attach the sheet aluminum box bottom. The aluminum sheet drops in from the top and is held by one screw in each corner. All holes and openings are part of the 3D model - no drilling required. MoI was also used to create the hole pattern template for drilling the aluminum plate. I just printed an actual size template from MoI onto paper, taped the paper to the aluminum, and took it to the drill press. The box is surprisingly ridged.:
Bottom view: Cables interface the fixture to additional outside electronic and electro-mechanical components:
The Arduino microcontroller provides the brains to run the whole process via a nested menu UI. I never programmed an Arduino before, but using some code snippets found on the Internet, it went pretty smoothly. The small holes in the lid access the button pads on the Arduino. For the moment I use a toothpick to access the menu buttons via the holes. Soon I'll 3D print some plastic shafts (buttons) to fit between the Arduino and the box lid.
