Hi Ralf,
> And now i have to right click all the buttons in MoI and see what happens... ;-)
Well also for the Hide button doing a Ctrl+click does a "Show subset" operation where it will temporarily show the current hidden objects, let you pick one or more of those and then go back to hiding everything other than what you just picked.
A right click on Copy or Paste will do CopyClipboardWithOrigin and PastePart instead of regular copy/paste, that's where you go right into orienting the pasted in part.
A right click on the Save button does "Save As".
A right click on View > Cplane will reset the cplane back to world default.
A right click on the style line in the properties panel when an object is selected will let you edit the style rather than bring up the menu.
And right click inside of a viewport is a shortcut for pushing the "Done" button or will repeat the last command if not in a command.
