Auto-retopology algorithms compared
 1-19  20-39  40-59  60-65
8817.40
Hi Stefan, Pilou and others,
Being in one of my many wrestling matches with the dreaded deadline monster, I regret not having found the time yet to try ZBrush 2019.
From what I've seen in the Pixologic introduction video I’m reasonably excited about ZBrush 2019. Personally I can’t wait to have a go at ZRemesher 3.0 with the new hard surface improvements. The subtool folders are great too, also the ability to use them in Live Boolean mode.
I feel a bit ambivalent about the Spotlight alpha mesher feature. It feels a bit like a revisit of the old Shadowbox, a feature I usually forget during modeling.
The NPR rendering possibilities look very good, but to me that also feels like going back in time about 10 to 15 years, back when finalToon, Pencil+ and Liquid+ were state-of-the-art 3ds Max NPR plug-ins.
Any tips and observations regarding ZBrush 2019 are welcome.
Thanks!
M7
Have you the OBJ files triangulated of objects concerned ?
Can you post them...
I have not yet the last Zbrush version, but I can make test them by someones! :)
@Metin,
No problem, i will see that i can try downloading ZBrush this afternoon.
@Pilou,
Michael has posted the original NURBS models, so you only have to load
them into MoI and then save as .obj.
However, when i come home i will try to download ZBrush and try myself then.
O.k., did a quick and not so much in-depth test.
The first object looks very good, while the second object has
some issues with the small ribs. I may have to check out
better settings, while i must also admit why to remesh such
objects … , when one could either use the .obj files from MoI
or model them directly with ZModeler …
1
2
8817.44 In reply to 8817.43
Hi Stefan, those are some good results!
> I may have to check out better settings, while i must also admit why to remesh such objects …
Well people ask for an "all quads" output from MoI pretty frequently, and these are the kinds of objects where it's difficult to do that (while also being not unusual CAD models as well) so it's a good example of why MoI does not have that function currently.
How these 2 objects have been transformed into OBJ format ? from what start format ? With what program ?
yes, I understand what you mean. Maybe people requesting such a feature are used to
subd modeling only, prior they discovered NURBS modeling and see a need for this?
But I have never read from them what purpose a quad only CAD model should serve.
Best regards
Michael posted the files in article 8817.23 of this thread. You only need to load
the models into MoI and then export from MoI as .obj, to load into ZBrush.
8817.48 In reply to 8817.47
I have missed the posts...
The original files are NURBS models, saved from MoI as
high-res quad/tries .obj meshes and then brought into
ZBrush for ZRemesher.
O.k., no problem.
8817.51 In reply to 8817.50
I don't remember if ZBrush accepts the Ngons ?
Haven't tried yet with 2019, but i remember from the past
it did not like ngons.
For this example i used quad/tris output from MoI.
8817.53 In reply to 8817.46
Hi Stefan,
Some people have the idea all quads = always good for everything, not all quads = always bad for everything. That can kind of get drilled in for people who have been very focused on sub-d modeling only for quite a while.
8817.54 In reply to 8817.52
<< For this example i used quad/tris output from MoI.
No more prudent only triangles ?
There is only that works not! (tell me if you see the images)
I don't know if the problem is from Moi (Nurbs to OBJ) or new ZBrush algorithm...
Inside Moi I take Maximum number of Polygons default, export only triangles and subdivide Larger than 2 unity / All
that was more false then less polygons and no subdivide Larger than
Inside ZBrush it's not me that make the test! (not yet install new zbrush)
Inside ZBrush : Import obj
Polygroups / Normals
Crease / Crease PG borders
KeepGroups & Keep Creases activated
SmoothGroups = 0
a new test must be arrived with a subdivide Larger than 1 unity / All
EDITED: 8 Mar 2019 by PILOU
very interesting. What i have tried now is to use Ngons/Quads, Mesh Angle 5
and then brought the mesh into Silo and applied a triangulation. My thought
was that then ZBrush must not compute so much when doing polygroups
from normals.
Maybe worth a try, because now i have all small ribs clean. In ZBrush i used
then only keep groups and did not use creases / edges feature.
I am sure your friend can archive much better results.
test2
EDITED: 8 Mar 2019 by STEFAN
8817.57
Hi all,
In the mean time I've installed ZBrush 2019 and had a go at it.
I have to admit I had higher expectations of ZRemesher 3.0. I guess it's more like ZRemesher 2.2 with sharp-edge support. It doesn't feel like a fully reinvented algorithm. As you can also see in Stefans image there are certain smooth areas where mangled multi-edge singularities occur, in favor of maintaining the sharp edges.
I had hoped ZRemesher 3.0 would make use of Machine Learning to recognize shapes and apply a 'Ground Truth' topology to it.
The rest of the features are of less interest to me personally. I experimented a lot with NPR rendering around fifteen years ago, when finalToon, Pencil+ and Liquid+ were exciting, state of the art 3ds Max plug-ins.
Next to MoI I find my focus centering on Blender more and more since the development of version 2.8. There are a number of free or very affordable add-ons that decrease my need for ZBrush as a companion tool.
I've post a top 5 of Blender add-ons that really help my daily modeling workflow to a separate MoI forum discussion here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9287.1
Regards,
Metin
EDITED: 10 Mar 2019 by METIN_SEVEN
Hi Metin,
i somehow agree with you, but on the other side i have not seen
yet a quad remesher which can replace ZRemesher yet. I doubt,
for example, that 3DCoat's autotopo tool can even handle Michael's
sample model properly. Maybe Marco or you can give 3DCoat with
Michael's test model a try.
I am very very thankful that Pixologic gives us still free upgrades,
so this should be no problem, money wise …
Regarding Blender, yes, it is a DCC app, especially 2.8, which everybody
should take a closer look at.
Best regards
8817.59 In reply to 8817.58
I think the general difficulty is that auto-retopo is targeting generating uniformly sized quads. That works well for the most common organic model type shaping but CAD models very often have a mix of large areas and then smaller sharply defined features.
Show messages:  1-19  20-39  40-59  60-65
