Auto-retopology algorithms compared
 1-12  13-32  33-52  53-65
Hi Chris,
Paul Gaboury showed once in a video, how to poly group a CAD model fast.
https://www.youtube.com/watch?time_continue=1&v=IzFZfJDQOOM
starts at 39:04.
Then you have also the option with MoI to create with a script random
style colors to a model and can use these for poly groups in ZBrush.
But to be honest why to auto-retopo a *MoI* CAD mesh... MoI has the
best mesher available! :-)
8817.34 In reply to 8817.33
Thanks for that link. I'll have to watch it several more times.
8817.35 In reply to 8817.32
Hi Chris,
Here's an image by a company called Kermaco I once found on Pinterest, explaining a multi-stage CAD model retopology process in ZBrush:
I expect you'll have to open the image in a new tab to see the full-size version.
Regards,
— Metin
visualization • illustration • animation • 3D design — metinseven.nl
Hi Metin and alll,
have you already tried ZRemesher v3? I have not downloaded yet, but i am
very curious how it would remesh the models Michael has posted.
BTW. i have just seen that there is an online version of Quadriflow.
https://yichaozhou.com/publication/1805quadriflow/#tool
8817.38 In reply to 8817.37
Quadriflow online : seems you can't upload your own model for quadrangulate it?
Else Zbrush seems robust :)
Sorry, overlooked it ...
So can you try ZRemesher v3 please, with the models Michael provided?
8817.40
Hi Stefan, Pilou and others,
Being in one of my many wrestling matches with the dreaded deadline monster, I regret not having found the time yet to try ZBrush 2019.
From what I've seen in the Pixologic introduction video I’m reasonably excited about ZBrush 2019. Personally I can’t wait to have a go at ZRemesher 3.0 with the new hard surface improvements. The subtool folders are great too, also the ability to use them in Live Boolean mode.
I feel a bit ambivalent about the Spotlight alpha mesher feature. It feels a bit like a revisit of the old Shadowbox, a feature I usually forget during modeling.
The NPR rendering possibilities look very good, but to me that also feels like going back in time about 10 to 15 years, back when finalToon, Pencil+ and Liquid+ were state-of-the-art 3ds Max NPR plug-ins.
Any tips and observations regarding ZBrush 2019 are welcome.
Thanks!
M7
Have you the OBJ files triangulated of objects concerned ?
Can you post them...
I have not yet the last Zbrush version, but I can make test them by someones! :)
@Metin,
No problem, i will see that i can try downloading ZBrush this afternoon.
@Pilou,
Michael has posted the original NURBS models, so you only have to load
them into MoI and then save as .obj.
However, when i come home i will try to download ZBrush and try myself then.
O.k., did a quick and not so much in-depth test.
The first object looks very good, while the second object has
some issues with the small ribs. I may have to check out
better settings, while i must also admit why to remesh such
objects … , when one could either use the .obj files from MoI
or model them directly with ZModeler …
1
2
8817.44 In reply to 8817.43
Hi Stefan, those are some good results!
> I may have to check out better settings, while i must also admit why to remesh such objects …
Well people ask for an "all quads" output from MoI pretty frequently, and these are the kinds of objects where it's difficult to do that (while also being not unusual CAD models as well) so it's a good example of why MoI does not have that function currently.
How these 2 objects have been transformed into OBJ format ? from what start format ? With what program ?
yes, I understand what you mean. Maybe people requesting such a feature are used to
subd modeling only, prior they discovered NURBS modeling and see a need for this?
But I have never read from them what purpose a quad only CAD model should serve.
Best regards
Michael posted the files in article 8817.23 of this thread. You only need to load
the models into MoI and then export from MoI as .obj, to load into ZBrush.
8817.48 In reply to 8817.47
I have missed the posts...
The original files are NURBS models, saved from MoI as
high-res quad/tries .obj meshes and then brought into
ZBrush for ZRemesher.
O.k., no problem.
8817.51 In reply to 8817.50
I don't remember if ZBrush accepts the Ngons ?
Haven't tried yet with 2019, but i remember from the past
it did not like ngons.
For this example i used quad/tris output from MoI.
Show messages:  1-12  13-32  33-52  53-65
