Freeze
All  1  2-6
8806.2 In reply to 8806.1
Hi eric, it's probably something to do with the Intel graphics driver - possibly more due to the software driver itself than the actual graphics card though.
The first thing to try would be to see if there is any newer graphics driver available.
The next thing to try is to disable multi threading in the MoI display engine and see if that avoids some conflict that's happening with the display driver. To do that you need to open up the moi.ini file and change the DisplayThreadLimit= option in the [View] section to DisplayThreadLimit=1
[View]
It also might be possible that v4 would work better on his system than v3 - v4 uses the newer Direct3D11 interface to the graphics card and that part of the graphics driver may be working better than the Direct3D9 interface that MoI v3 uses. To test v4 on his machine, copy your v4 install directory C:\Program Files\MoI 4.0 beta Dec-12-2017 onto a USB key and also copy your license key files from %Appdata%\moi onto the USB key too alongside MoI.exe then you can run it on his system to test it.
If none of these things makes it any better than it's probably that the graphics card is just not up to it. Unfortunately those all in one systems probably don't have any way to upgrade the video card.
8806.3 In reply to 8806.2
Thanks so much Michael.
I will follow up with him next week.
cheers,
eric
8806.4 In reply to 8806.2
Hi Michael
I thought the ver 4 beta might be updated today.
I'd like to install it on a USB Flash drive to take to a meeting with my client with the Aspire All in One on Friday morning.
Do think you might have the release out tomorrow or should I just use the present version?
thanks,
eric
8806.5 In reply to 8806.4
Hi eric, I'm sorry I'm not sure if it will be out tomorrow. Maybe but some of the last details are being a bit stubborn.
I'd say go with the current version, it's always possible that a new release can also have new bugs in it too.
8806.6 In reply to 8806.5
Thanks for the quick reply Michael.
Yes,
I'll use the present version unless the birthing happens tomorrow afternoon.
Get some sleep ... I'm off for some, myself.
cheers,
eric
Show messages: All  1  2-6
