Dimensions again
8800.1
Until dimensions, hopefully, appear in v4, I would like to try out "Dimensions.v.1.0.2015.09.14.zip" by max Smirow. I have downloaded it, a html and a javascript file. How do I install this, thanks?
best
Claus
8800.2 In reply to 8800.1
You can Press TAB and write _dimensions or _Dimensions but without space !
or make a Shortcut as usual and write _dimensions on the second column
EDITED: 30 Jan 2018 by PILOU
8800.3 In reply to 8800.1
To install custom scripts in Moi have a look here:
http://moi3d.com/wiki/FAQ#Q:_How_do_I_install_a_plug-in_script.3F
after this you can add a shortkey, or using the command bar like Pilou sad to use the script
8800.4 In reply to 8800.3
Merci All !
