Moving line endpoint
8794.1
Hi, old Danish beginner here.
I need to be able to grab one line endpoint and move it around, while the other line endpoint stays, where it is. Is this possible in MoI? - Thanks.
8794.2 In reply to 8794.1
Hi Claus, welcome to the forum!
You can move just one end of a line by selecting the line and then using the Edit > "Show pts" button in the side pane.
With the control points turned on you can now select just one of those control points and drag it or use other Transform commands on it.
8794.3 In reply to 8794.2
Thank you. Can now go on exploring - best Claus
