Booleans and Filleting
All  1-7  8-10
879.8 In reply to 879.6
> but maybe I shouldn't rely on booleans too much... but it's so fast and sweeeet! :)
Actually, it's fine to rely on the booleans... This really isn't a problem with the booleans, the problem is with the filleting mechanism...
Sometimes you can do a few steps to make things work better - like for instance if you're going to do a boolean with a cylinder, there is an extra "seam edge" that runs along one side of the cylinder where the surface comes to be closed. Sometimes it is possible to rotate the cylinder so that particular edge is not running right close to other things before you do the boolean, or even so that it won't be a part of the result since it will be in a trimmed away area. That makes less edges and less opportunity to run into the fillet bugs that won't cross interior edges.
879.9 In reply to 879.1
One other note about fillet size - it is really pretty easy to underestimate how much of a model a particular fillet size is going to consume when the model is made up of some narrow or concave type areas.
For example, here I've applied a fillet of radius 3 to your shape, by using Edit/Separate on the model to break it into individual surfaces, and then picking the inside scalloped area and then outside sphere surface. This does the surface/surface fillet operation instead of the edge-based one.
This is the same radius fillet as the little fillet pieces on the original shape around the eyes! But since there is a sort of narrow pointy area in the scalloped out shape, a fillet of that radius consumes quite a lot of the shape before it will fit, this would include eating up those eyeball parts entirely.
So it can be pretty easy to run into this problem where you are asking for a fillet that simply won't fit in the model at all.
That's why it can be a good idea to go down really pretty small if the size that you first try does not work.
879.10
Awesome!
Thanks a million for your pointers, can't wait to get home and try some modeling again!!
Cheers,
Jens
Show messages: All  1-7  8-10
