join curves
8785.1
Hi ..
Now and then I create a flat surface (or hope to) by offsetting lines (or copying) and then drawing lines between the ends and using 'join' to connect. Then I use the 'planar' command to create the surface ... but there are times when that does not happen. I can't see that the curves are not planar or properly joined.
When this happens I open the drawing in Rhino and use 'closecrv' command which reports that a segment has been added.
Then back to MoI and the planar command creates the surface.
Is there a way to do this without going to Rhino for the fix?
eric
8785.2 In reply to 8785.1
Hi eric, there's a CloseCurve command for MoI here: http://moi3d.com/forum/index.php?webtag=MOI&msg=2752.2 . That will make a line segment between the ends of an open curve like the Rhino CloseCrv command.
Hope that's what you were looking for!
8785.3 In reply to 8785.2
Hi Michael ..
Thanks, yes that's perfect!
eric
