Import edges without faces (3d) to MoI
All  1-4  5-6
8782.5 In reply to 8782.4
I totally agree with you, that method of copying and pasting is much simpler.
8782.6 In reply to 8782.1
Hi bartosh, there's also an OBJ to 3DM wireframe converter here:
http://moi3d.com/resources#Obj23dmWireframe_converter
That will load an OBJ file and save out a 3DM file that has line segments generated for the polygon edges.
DXF export from Modo probably makes what's called a "polyface mesh" entity in the DXF file, which is a polygon mesh made up of triangles and quads. MoI's DXF importer does not read those types of entities out of a DXF file, it only loads wire type entities like lines, circles, arcs, polylines and splines.
Show messages: All  1-4  5-6
