Settings for OBJ export?
All  1  2-4
Hi Nick,
looks to me that you have an issue with the normals. I would check
your import settings, if there is an option shown for normals and then
uncheck this option, so that the original normals from MoI don't get
modified or discartet.
Here are the settings i used for your model and the model shows
in Thea no shading glitches.
Hope this helps!
8761.3 In reply to 8761.1
Hi Nick, yes like Stefan writes above it looks like you're not getting vertex normals coming through.
In C4D look under Edit > Preferences > Import/Export > "Wavefront Import" and make sure "Import Normals" is checked.
You want to make sure the object is shaded using the vertex normals that are stored in the .obj file, those normals come from the original NURBS surfaces and help make the rendered polygons have the same shading behavior as the original CAD model.
If the vertex normals are discarded and instead created by averaging polygon faces it usually results in the type of artifacts that you're showing there.
8761.4
Thank you Stefan and Michael
I really appreciate you guys taking the time, this forum is the friendliest and most competent I know.
Thank you so much!
Show messages: All  1  2-4
