Croping in MoI???
875.1
Hi everyone. I am new in 3D modeling and learning to work in POSER 7. I discovered MoI two days ago and I am impresed. Beautiful interface and very powerfull tools. My question is HOW TO CROP MODELED SHAPES ? I want to cut off some unnecessary parts and I don't knw how. I tried out TRIM tool but didn't make it......how to do this ?
875.2 In reply to 875.1
Hi Pozero - Trim is one method you can use to cut things up. If it isn't working for you, please post a model file here and I can take a look and see what problem you're running into.
But actually the Boolean operations are probably what you want.
Here for example I have drawn 2 objects - a sphere, and then a line which will be used to cut the sphere:
To perform the cut, select the sphere first, then run Construct / Boolean / Diff. Now select the line as the cutting object and then click "Done" (or right click in a viewport which is a shortcut for pressing Done).
That will cut the sphere by the line and leave the pieces behind - select and delete the pieces you don't want. Here I have moved the pieces to show the result:
Hope this helps! If you're having problems with a particular model, please post the model file.
and the funny thing is that the "curve line" must not be obliged to cross over the sphere!
Just "in front of" in view face for example :)
EDITED: 28 Aug 2007 by PILOU
875.4 In reply to 875.2
Thanks Michael!!! I' ve done it finaly. It was simple option but I am just begginer. Great tip.
