Multiple sweeps
 1-7  8-27  28-36
8739.28 In reply to 8739.22
Hello Mat!
As promised here's a little tutorial about the section of my previous video where I use the "project" command : where and why.
This is the video : http://take.ms/S76EV
(it's about 240Mb so if you have a slow connection maybe it's better that you first download it and then watch it)
As usual, the way I show you in this tutorial is jut one of many alternative ways that you can follow to achieve the same results.
It depends on what you want to do and what kind of model you are treating.
As I said in other post, for me Moi is like a video game and sometimes I prefer to follow a certain technique that maybe can be slower than other
but for me in that particular moment is more fun :)
1) I use the project command to create this blend :
2) At some point I've used the Max's ScaleIndividual commad : get it at http://take.ms/mzlCqv
(unzip and copy the .htm and .js files into the Mo's "commands" folder)
3) how did you go from the Isos to the pipes?
I did it in one shot.
I've simply created a circle somewhere on the top plane, then I have selected all the sweep rails (created with iso command) and finally I have performed the
Sweep with "pointy end" Ends.
I hope I made myself clear enough :)
Ciao!
8739.29 In reply to 8739.5
Hi Karsten,
I got the Node you sent to work.
Loaded up the additional extensions from the link you provided (I had read chunks of that thread before to get started in NE).
I see the "isoCrvs" option in the menu...but I still don't see the "getCrvSFrame" option...was that renamed?
I noticed in the right hand side of the circular array, the pattern is not evenly spaced, slight gap. I put 20 in BRep...I get 21 in the output..? And the pattern is not evenly spaced. How to you adjust or set spacing?
Thx.
8739.30 In reply to 8739.29
Hello Mat,
getCrvStartFrame should be found under Points2 3rd option from the top. The problem with the missing element is caused by the effect that MoIs isocurve factory don't give a result from the edge. So if you want that, you have to use individual spacing supported by the node and give so a point very close to the edge. Try this please:
You can also calculate the values and add them with concat to 0.001.
Have a nice day
Karsten
p.s.: Switch also in isoCrvs to edge E1 and look what happens:-)
EDITED: 16 Dec 2017 by KMRQUS
8739.31 In reply to 8739.28
Hi Marco!
Thanks for much for the video, very helpful. Appreciate you taking the time.
3) Ok, I figured you had used a profile somewhere to get the pipes.
I gotta ask...how do I get those great rendering viewing options from the light bulb button? I have the button from Max's custom UI...but no lighting options presets?
Thx!
8739.32 In reply to 8739.30
Hi Karsten,
I see the "getCrvStartFrame" now...missed it with all the options in my now updated library.
Is there some resource where I can learn what all the nods do and what they names mean? You mentioned "concat"...no clue, ha.
Are these terms from Grasshopper or related to Grasshopper? I've played with GH a little bit with Rhino.
Maybe a better question is...what is the functional relationship between NE and Grasshopper? Or no relation at all?
"const" with the value settings you used worked great to array.
Cool trick with "edge 1" too!
I'm hooked on NE...need some resources to learn what does what, how and why.
Thx!
Mat
8739.33 In reply to 8739.32
The only complete ressourse are the 2 Threads themselves! ;)
Official Max Smirnov Elephant : http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.1
and the deviant by some genious coders!
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1
I have a data base but in French because I translate Elephant and all nodes that please to me that are not inside the native Elephant! :)
But you have all original links! ;)
what, how and why is only a question of hard training! :)
I am not sure that me, myself and I, be the best one for that! :)
EDITED: 16 Dec 2017 by PILOU
8739.34 In reply to 8739.31
Hi Mat.
For custom" Lighting Options" you can follow this old thread by the great "K4ICY" user.
http://moi3d.com/forum/index.php?webtag=MOI&msg=5222.6
"K4ICY" have created also a bunch of excellent modelling tutorials!
IMHO the best tutorials ever seen on the Moi's forum:)
http://www.k4icy.com/tutorials.html
Ciao!
8739.35 In reply to 8739.33
Bonjour Pilou,
Zut, mon français ne pas très bien. Vous avez un bon website avec tout les choses de nods.
I guess I better get reading on those Moi threads!
Merci beaucoup!
8739.36 In reply to 8739.34
Hi Marco,
Thanks for the links! I will check them out for sure!
Show messages:  1-7  8-27  28-36
