V4 beta Dec-12-2017 available now
 1  …  82-101  102-121  122-141  142-161  162-176
8731.122 In reply to 8731.121
I SPOKE TOO SOON.
I changed the Nvidea setting right after I sent the last post and I couldn't duplicate the glitch again.
Thanks Michael. Your responses are incredibly fast. I have been waiting days for a response about Sim 8.
cheers,
eric
8731.123 In reply to 8731.117
Hi Michael.
Thanks for the tip.
Could you explain more in depth what those settings do (both for Nvidia side and Moi) ?
They do a downgrade of the performance ?
Marco (mkdm)
8731.124 In reply to 8731.123
Hi Marco, those settings make the video driver or MoI make use of multiple CPU cores to do some portion of the display work. But using multiple cores is an inherently difficult thing to make work properly, every thread that might access the same memory has to be synchronized with each other. In some versions of the nVidia display driver this has been buggy so if there is any odd display behavior it can be good to try turning off that option in the nVidia driver. There will be some performance cost to that, it's hard to say how much exactly it's going to be system specific.
8731.125 In reply to 8731.124
Ok Michael.
Thanks a lot for clarification.
I have a brand new Gtx 1080 Ti and I didn't notice particular issue with MoiV4 so far.
But ASAP I will make other tests.
What I really wait is the ability by Moi to use "all" this GPU power for its display routines,
because till now all my GPU cudas and VRAM (11 GB) are almost unused by Moi.
But I know that you already told me that this feature will be implemented as soon as V4 will be very stable and tested,
so no problem :)
I can wait.
Have a nice day.
8731.126 In reply to 8731.125
Hi Marco, well if you had this problem it seems like you'd have noticed it by now. Your combination of driver + system setup probably doesn't expose whatever driver bug is happening here. If you have not seen any intermittent freezing you shouldn't modify these settings.
8731.127 In reply to 8731.126
@You : "If you have not seen any intermittent freezing you shouldn't modify these settings."
OK! Got it.
Anyway ASAP i will make other tests with some heavy 3dm scenes in 3D view full screen inside Moi.
I will let you know.
We'll catch up.
8731.128 In reply to 8731.127
Hi Marco,
If the purpose of your test is to see if you have the intermittent freezing issue that's been recently discussed you just need to test a very light scene as alksndr was showing here:
https://imgur.com/GwAndSt
8731.129 In reply to 8731.128
Got it!
OK, I'll do that, then
8731.130
I'm currently using the Moi 4 BETA to clean up some .SAT files. While importing the object it is fully joined. After I repair some areas, save the file and reopen the object is separated so all surfaces are not joined. This wasn't happening with V3. Has something changed which is separating the objects after deleting some areas and/or saving?
8731.131 In reply to 8731.130
Hi Puz, it is possible for it to happen in v3 too - the SAT importer will do this if it has certain kinds of errors when processing the imported trimming boundaries.
So it's likely to be something that's specific to that particular file. If you make something simple in v4 like a box and then export it and import it back again do you get a solid?
Is it possible for you to send the file to me at moi@moi3d.com so I can take a look?
8731.132 In reply to 8731.131
I tested the same file on both versions of Moi. I'm assuming it must be related to the file, but wasn't sure why 3 wasn't separating it, but 4 was.
Unfortunately, I cannot send the file. Although I did test exporting/importing a simple shape and that behaved correctly. I guess you'll have to file this one under "odd behaviour of complex file error". I'll make some further tests to see if it happens again.
Hi Max, I've finally had a chance to examine the SpherePoints+ performance issue you wrote about here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8682.16
quote:
4. Interactive scripts perfarmance problem. MoI v4 18.11 works much faster than with 13.11, but still
slower than MoI v3/4(Win) and v3.1(Mac).
You can check it with my SpherePoints+ script. http://moi.maxsm.net/item/2
After some testing to rule out draw performance I was able to determine that it's due to the script using window.setInterval() to look for updates. It seems that recent WebKit and Chrome browsers delay the .setInterval timers if there is other intensive activity like continuous movement of the mouse I guess. I'm not sure why it only happens in MoI on the Mac version, maybe only the Mac OS happens to have the support for it.
There's a discussion of it in Chrome here:
https://bugs.chromium.org/p/chromium/issues/detail?id=570845
I haven't found the checkin that added it to Webkit but a lot of times Webkit and Chrome copy stuff from each other since only a few years ago they were the same codebase.
It sounds like it might be possible to use a different web timer api "requestAnimationFrame" which might not get delayed like setInterval:
https://stackoverflow.com/a/43951402
but I did not test that.
For this script it would be better to not use a timer at all and instead update things when a UI event is fired, that should ensure no delaying and also not burn CPU cycles by continuous polling when nothing is being actually changed in the UI. I've attached a modified version of SpherePoints+ that does it like that and it seems to solve this Mac performance issue. If you have this same problem in other scripts that are also using window.setInterval then it's likely to be the same thing there. Please let me know if you have seen any other script performance regressions in v4 that do not involve setInterval.
Hope this helps! - Michael
EDIT: forgot attachment
EDITED: 20 Jan 2018 by MICHAEL GIBSON
8731.134 In reply to 8731.133
Yes, there something strange with webkit timers. Nodeeditor also uses setInterval, but it works much smoother than my SpherePoints script.
When I move mouse cursor inside Nodeeditor window - everything works good, but when I move cursor outside the window - a significant stutters appears.
Thank you for links, I'll read it tomorrow.
Yes, you're right. Your script works faster.
I tested all my scripts with MacOS 10.13.2 - everything works great (except the scripts which uses setInterval). I noticed significant performance increase!
For example, Cloth simulation script works about two times faster than before. I'm impressed.
EDITED: 7 Mar 2022 by SMIRNOV
8731.135 In reply to 8731.134
Hi Max,
Great! I wasn't really sure exactly how the 64-bit build work out for script performance.
The one other v4 performance regression that's been reported is Extrude giving lagging feedback in the Mac version. I've got a fix for that for the next beta.
8731.136
Hi I was wondering if in the future there will be a native version for linux? Thanks :)
8731.137 In reply to 8731.136
Hi pafurijaz,
Right now there isn't any set plans for that, but it could be possible in the future if there is an increase in demand for it.
It takes a substantial amount of work for each additional platform. I'm stretched pretty thin as it is just supporting Windows and Mac native builds.
Is there a way for a script to tell if it is running in MoI3 or MoI4? A version tag or flag?
8731.139 In reply to 8731.137
Thanks, I hope for you and for me but especially for Linux, that there is an increase in demand, I will do propaganda in my little;)
8731.140 In reply to 8731.138
Try moi.majorVersionNumber, that will be a numeric value of 3 or 4 for v3 or v4.
There is also moi.version which returns a longer string like "4.0 Beta Dec-12-2017".
Message 8731.141 deleted 24 Jan 2018 by BEMFARMER
Show messages:  1  …  62-81  82-101  102-121  122-141  142-161  162-176
