Rendering - tips, tricks, experiences
 1-11  12-31  32-51
8728.12 In reply to 8728.10
Hi Marco,
I guess Karsten meant that Luxrender is slow, not Blender or Cycles. :)
Regards,
— Metin
visualization • illustration • animation • 3D (print) design — https://metinseven.com
8728.13 In reply to 8728.11
@You : "...Octane Standalone..."
Octane....great package!! Very powerful with a powerful GPU!
Unfortunately it's $399 :(
Ciao!
8728.14 In reply to 8728.12
Ho...yeah!
Luxrender....for what I've tried some times ago it's a snail :)
Terrific photorealistic results but unless you have tons of cores or a super powerful CPU (like xeon)....
Maybe with a Tesla or even with a "consumer" Gtx 1080 Ti like mine, the results could be a little better but...
Life's too short to see a gauge bar reaching its end :)
Ciao!
8728.15 In reply to 8728.10
Hi Stefan,
I try to answer in this thread on question from http://moi3d.com/forum/index.php?webtag=MOI&msg=4446.193
I probably know, what you mean... for example here http://moi3d.com/forum/index.php?webtag=MOI&msg=8600.10
... reflection on chrome axle inside suspension spring isn't align correctly.
( I hope that Zarkow will not be angry at me, because I admire his creativity, scene compositions and illumination of render ... we try to analyse only Octane performance :-) )
I think that sharpening of image can accentuate this artefact on the other hand right settings of render kernel inside Octane can improve this artefact, especially Filter size ( "Sets the filter size in terms of pixels. This can improve aliasing artifacts in the render. However, if the filter is set too high, the image can become blurry." ...source here https://help.otoy.com/hc/en-us/articles/115001714686--Pathtrace-Kernel )
As you can see from render a lot of "hot pixels" (fireflies) are visible....a very simple trick can be used to reduce/eliminate them... it is good to set double render size as required and then resize the picture by 50%, then hot pixels disappear, you can try it if you download the origin Zarkow's render DIN A3 size.
I've found quite good Octane tutorials ( https://www.youtube.com/watch?v=zXUE-39fwug&list=PL0DBA6671E0A1743B )
Mik
8728.16 In reply to 8728.13
Yeah...But leveraging that against the typical revenues of a job / time saved I think it's a valid purchase ;)
- Rich
8728.17 In reply to 8728.16
Hi Marco,
I plan to compare Octane vs LuxRender standalone both in Linux version, so I am curious to know the results :-)
Ciao
Mik
8728.18 In reply to 8728.14
Hello Marco,
yep it's a snail, but the only way is to use a physical renderer, if you want to test the look and feel in some applications. Target isn't a beautiful Rendering or photorealistic Rendering - more a realistic rendering in the meaning of a Simulation. e.g. optical Systems. So everyone has a different Point of view.
Have a nice day
Karsten
8728.19 In reply to 8728.18
Oh yes Karsten!
@You : "...different Point of view..."
You're right.
In fact for me the key feature is the speed rather than photorealism :)
Have anice day.
Hi Mik,
thanks for the detailed response. I think the trick with rendering larger images and then reducing them in pixel size afterwards
helps also to reduce the aliasing issues and not only getting rid of fireflies, without using the filter, because it should give the
render engine "more room" to draw those areas. At least, i remember this from long time ago when reading about render tips.
Best regards
8728.21 In reply to 8728.20
Hi Stefan.
@You : "... think the trick with rendering larger images..."
Yes, undoubtedly in this way you can get a less pixelated final image but at a cost of much more render time.
I you render a frame at 4K resolution and then you perform a scale down to a FullHD res, for sure you
will get a better looking image but the initial render time is increased by 4x!
If the time is a key, this method is not good at all.
You can get better results in terms of time and also, is some circumstances, in terms of quality,
if you use a software like Affinity Photo or others to apply a post process effect to the rendered images.
Furthermore...I've tried also the (now official) "Denoising" feature of Blender 2.79 and in many circumstances it can offer great improvement to the final render at a cost of a small fraction of increased time (about 20%).
Ciao!
Hi everyone.
Just in order to close an open discourse...
After many considerations and tests I decided to get rid of the trial version of Simlab Composer Pro.
This was the third time I've given this software the chance to be included into my current pipeline,
but another time, and this time is the last time, I understood that this product makes no sense to me, now.
As I said I've invested my money into a "consumer" but powerful GPU (1080 Ti) and Simlab is CPU bound.
Furthermore its material database library is not better than the one I have with Thea Render,
and for all other "rendering things" I can leverage on Blender with its GPU Cycles engine,
and Blender can offer tons of features and is totally free.
If I decided to invest my money on a powerful multicore CPU (Ryzen or Threadripper or i9) rather than a GPU, maybe I could have given to Simlab another chance.
Have a nice day to all and thanks anyway for suggestions :)
Ciao!
Marco (mkdm)
Ah....the old ever green Blender's "Suzanne" :)
(Via FotoSketcher....thanks Pilou)
Ciao!
Hi Marco,
I prefer quality over quantity and if i need super duper fast renderings
i can use a french Supercomputer... :-)
Since this is a rendering tips and tricks thread it would be helpful for the general audience if you could
show us an example (original with some aliasing and one reworked with Affinity Photo).
Best regards
8728.25
Hello,
has someone tested CADRays?
- Karsten
8728.26
Hi Karsten,
I hadn't heard of CADrays yet, thanks, I'll check it out.
Also interesting is AMD Radeon ProRender. Fully free and supported by a number of 3D editors, including Blender and Maya. It uses OpenCL, so it utilizes rendering power of both CPU and GPU.
https://pro.radeon.com/en/software/prorender/
Regards,
— Metin
Message 8728.27 deleted 19 Dec 2017 by CEMORTAN_TUDOR
8728.28 In reply to 8728.26
Hello Metin,
thanks for the link!
565MB download for the ProRender for linux. There was a time that a rendering tool fits to 3 3 1/4" disks with 1.4MB ... okay 25 years ago!
- Karsten
Hi Karsten,
if you are looking for a small (Windows) production renderer maybe the famous japanese Redqueen
Renderer is something for you. It requires editing text files, in order to use this little and fast render
engine.
https://github.com/shinjiogaki/redqueen
and some gallery images:
http://azurite.jp/gallery/index.html
EDITED: 21 Dec 2017 by STEFAN
8728.30
Hi Karsten and Stefan,
Karsten: Yeah, good old times when everything fitted on a few diskettes. :) Amiga rules! :D
Stefan: Wow, Redqueen's results looks great. It's a pity that the coder won't update it anymore, because he's employed by Solid Angle, creators of the Arnold renderer.
Regards,
— Metin
Hi everyone!
Instant Light (realtime render engine), an amazing companion for Moi and 3D-Coat, has been updated to 1.5.11 stable beta!
On my Gtx 1080 Ti it has superb realtime performance.
https://www.youtube.com/watch?v=oR9jaxohxAY&t=7s
Ciao!
Show messages:  1-11  12-31  32-51
