File window list reset?
All  1-7  8-9
8721.8 In reply to 8721.7
Hi Mat,
> ...Some of the Zs in the lines are capital after the = sign, most are lower case, not sure if that matters for anything.
That doesn't matter.
> ...Do I delete the entire line? Or just a certain section of the line?
Just delete entire lines that you don't want anymore and edit the numbers before the = sign so there aren't any gaps.
> 2. On the Recent Files List - changing the order question
> Found the Filemenu.htm as you instructed...but for some reason when I click on "text editor" on
> my Mac...I get a blank page...nothing is there, no lines of code.
Oh yeah when this happens it means TextEdit is trying to display the HTML to edit it rather than editing the raw text directly. I think there's a menu option somewhere to switch that behavior or you could try using Notepad++ instead.
See here for some instructions on how to do it with TextEdit:
https://computers.tutsplus.com/tutorials/quick-tip-configure-textedit-for-coding-html--mac-44786
8721.9 In reply to 8721.8
Thanks for the link Michael...now I can see the HTML text! Just had to change basic settings in TextEdit.
Show messages: All  1-7  8-9
