Image * 4 (or more if $) online..
http://bigjpg.com (Claytownpainyings)
https://letsenhance.io (thx MetinSeven)
with new technology of neuronal system! :)
a little try with my avatar! :)
Original
x4 With an old program
with bigjpg
with bigjpg
EDITED: 28 Nov 2017 by PILOU
8707.2 In reply to 8707.1
This is a really good enlargement tool ... can't get equal results in Photoshop despite my best attempts.
EDITED: 28 Nov 2017 by CHRIS_DORDONI
8707.3
Thanks for sharing your discoveries, Pilou. Always appreciated.
I've been doing comparative tests between image enlargers for years, and I keep coming back to Photozoom Pro ( http://www.benvista.com/photozoompro/ ). The second best enlarger is Alien Skin's Blow Up ( https://www.alienskin.com/blowup/ ), although that hasn't been really updated for years by the time I write this.
Big JPG (and maybe Let's Enhance too) uses the fairly old WaiFu2x algorithm ( http://waifu2x.udp.jp ), which is very good, and comparable to Photozoom Pro, but without Photozoom Pro's extensive options and friendly UI.
There's also a free open source image enlarger called SmillaEnlarger ( https://sourceforge.net/projects/imageenlarger/ ), but it hasn't been updated for more than a year by the time I write this.
Pilou, here's your avatar enlarged using Photozoom Pro:
Original:
Photozoom Pro, 400% enlargement, Reduce JPEG Artifacts option set to 'Extreme' (more smoothing, at the expense of detail blurring):
Note that most of the jagged edges have been smoothed out by Photozoom Pro's S-Spline algorithm, especially the aliased pixel edges. If you compare the eye spirals with the other enlargements, I think Photozoom Pro gives the best result.
Regards,
Metin
visualization • illustration • animation • 3D (print) design — https://metinseven.com
EDITED: 29 Nov 2017 by METINSEVEN
8707.4 In reply to 8707.3
Thx for the effort and Infos!
Of course my original "original" was not perfect! (made in less 5 minutes maybe less one minute (thx ZBrush Texture 47 (?) - i don't remember! )
So they are enormous jaggy artefacts (black lines on the spheric volume part ! )
But this avatar is now well known over the 3D/2D world! :)
8707.5 In reply to 8707.4
I think your avatar should become the default image enlarger test. :D
Regards,
— Metin
8707.6 In reply to 8707.5
Sure but i love also the rustic side! :)
