Scripting: NumericTextEntry doesnt give a "onChange" event
8694.1
Working on my script, i'm running into this:
I have 3 values, if i change on the others should be updatet.
It works fine as long as i mark the values with the mouse - change them - hit enter -other value is updated.
But if i click into the input the NumericTextEntry comes up - i change the value - hit enter (or click Okay) - nothing.
The NumericTextEntry doesnt give me a onChange event
How can i solve this?
Ralf
the htm file:
<html xmlns:moi>
<head>
<link rel="stylesheet" href="moi://ui/moi.css" type="text/css">
<script>
var opt;
function UpdateValues(opt)
if(opt ==1){
scale.value=newD.value/oldD.value;
}else{
newD.value=oldD.value*scale.value;
alert(opt);
</script>
</head>
<body class="commandbody">
Change Hole
Select all faces of the hole
Pick basepoint
Change Diameter
<moi:CheckButton id="subtype" style="persist:true" default=true>Keep Tool</moi:CheckButton>
<moi:NumericInput id="oldD" style="width:4em;">
<nobr> Old diameter</nobr>
<moi:NumericInput id="newD" style="width:4em;" onchange="UpdateValues(1);">
<nobr> New diameter</nobr>
<moi:NumericInput id="scale" style="width:4em;" onchange="UpdateValues(0);">
<nobr> Scale factor</nobr>
<nobr>Scalefactor</nobr>
<moi:Slider id="diameterSlider" min="0" max="5" style="width:90%">
<moi:NumericInput id="scalez" style="width:3em;" default="1" binding="diameterSlider.value = this.value">
<moi:CommandCancel>
<moi:CommandDoneCancel>
</body>
</html>
8694.2 In reply to 8694.1
Update for a changed .htm entry is often done in the .js code, with moi.ui.commandDialog.waitForEvent()
For example, see LineWeb.js. (I cannot comment on your code.)
- B
8694.3 In reply to 8694.1
Hi Ralf, try using onvaluechange="" instead of onchange="" .
The onvaluechange="" is a custom event that MoI fires which should work for both of those cases. That's there because in MoI v1 and v2 it wasn't easy for me to customize the standard onchange event, so MoI controls used a custom one instead.
I'll look into making the standard onchange="" work now as well though.
8694.4 In reply to 8694.3
YES this works
Thank you very much!
Ralf
