Hi Digitaluka, MoI v3 only supports FBX version 6100 and so won't work with Blender 2.79 .
The MoI v4 beta however has an updated FBX library and can be configured to write later versions than 6100.
To do this open up MoI v4 and go to Options > General > "Edit .ini file" button.
Inside the moi.ini file find this section:
[FBX Export]
If not found, add it to the end and then add in an entry under it for FBX Version=2014 so it looks like this:
[FBX Export]
FBX Version=2014
With that in place MoI v4 will write a newer version of FBX files which should then work with Blender.
You can put any of 2010, 2011, 2012, 2013, 2014, 2016 to control which version of FBX MoI v4 will write.
You can get the v4 beta from here: http://moi3d.com/beta.htm .
