Invisible Layers when opening 3dm from Rhino
All  1-2  3-4
8681.3 In reply to 8681.1
Hi Muha, yes it's likely what Marc writes above where your object is a block instance or mesh object. If it's a block instance you'll need to use the ExplodeBlock command in Rhino on it to convert it into a regular object before MoI will be able to see it. If it's a mesh object then it's a different type of data than what MoI works with.
8681.4
Good morning,
thank your for your answers and your help.
The needed part is a block instance.
Good to know that I need convert those instances into regular meshes.
Show messages: All  1-2  3-4
