Invisible Layers when opening 3dm from Rhino
8681.1
I have one problem when opening 3dm files from Rhino.
There are several layers that are invisible.
When I click on "Browser" and "Styles" I can see the layers but I can not activate them or make them visible.
Unfortunately the piece of geometry that I need is on one of those layers that do not work.
In Rhino everything works well and I can select the geometry.
Unfortunately I can not save in Rhino into STP or something else becouse I have only a trial.
At the moment I try to find out if I should invest into Rhino or MoI.
I really like the results that MoI delivers, when converting NURBS into Polygons.
But if I can not open the 3dm that my clients send me this is useless for me.
Did anyone had similar problems with 3dm files from Rhino?
8681.2
If I remember, block instances or polygonal data it wont show in Moi, maybe it's this.
Marc
8681.3 In reply to 8681.1
Hi Muha, yes it's likely what Marc writes above where your object is a block instance or mesh object. If it's a block instance you'll need to use the ExplodeBlock command in Rhino on it to convert it into a regular object before MoI will be able to see it. If it's a mesh object then it's a different type of data than what MoI works with.
8681.4
Good morning,
thank your for your answers and your help.
The needed part is a block instance.
Good to know that I need convert those instances into regular meshes.
