when the final version?
868.1
very very nice modeller,
i use rhino acad maya and solidEdge but moid3d it's best intuitive software.
it' important add extract curve from surface in the final version, and rebuild curve with semplify point.
thanks
868.2 In reply to 868.1
Hi Alariv, the final version will be released just as soon as the documentation is complete. It will be the same as the current beta except for bug fixes.
For extracting an edge curve of a surface, select the edge and then do copy + paste.
There is no rebuild function yet, I will definitely be adding that for version 2 though.
868.3 In reply to 868.2
Ah ...extract curve from edge work well, it's possible extract iso curve from one object?
868.4 In reply to 868.3
<it's possible extract iso curve from one object?
Maybe you can if you use the function Curve / Project with a simple line in front of your objects :)
That draw any any curves follow any direction you want and exctract it of course
868.5 In reply to 868.3
Hi alariv,
No, not presently - as Pilou mentions you can use Construct / Curve / Project or Intersect to create curves though.
Extracting isocurves isn't in version 1.0, but I do want to add it in a future version.
868.6 In reply to 868.5
I guess it must be soon, and it seems too the price has been defined:
http://www.deelip.com/2007/08/solid-modeling-for-195.html
Cheers,
- Diego -
868.7 In reply to 868.6
Interesting text and reply from Michael :)
