Hi matt, so for setting up buttons on the View tab in the side pane, you would need to edit the SidePane.htm file in a text editor like Notepad++ .
The existing view tab is this, do a find for "ViewTabContent":
<div id="ViewTabContent">
<table>
<tr>
<td><moi:CommandButton icon="ViewReset.png" onclick="moi.view.resetAll();"><moi:Text textid="Reset all"/></moi:CommandButton></td>
<td><moi:CommandButton icon="icons/ImageIcon.png" command="image"><moi:Text textid="Image"/></moi:CommandButton></td>
<td><moi:CommandButton icon="icons/CPlaneIcon.png" onclick="if ( event.button == 2 ) { moi.view.resetCPlane(); } else { moi.view.setCPlaneInteractive(); }"><moi:Text textid="CPlane"/></moi:CommandButton></td>
</tr>
<tr>
<td colspan="3" style="padding:0.1em 0.4em 0.2em 0.4em">
<moi:CheckButton style="text-align:left;" binding="value = moi.view.showHiddenLines"><moi:Text textid="Hidden lines checkbox"/></moi:CheckButton>
</td>
</tr>
</table>
</div>
So to add in a new row of buttons you'd need to add a new table row ( ) and table cells (| ) that have buttons in them (<moi:CommandButton). Which would look something like this - new lines added between the new stuff start and new stuff end markers and note the new stuff is added before the closing |
<table>
<tr>
</tr>
<tr>
</td>
</tr>
<!-- new stuff start -->
<tr>
<td><moi:CommandButton icon="SetView1.png" onclick="script:var vp = moi.ui.mainWindow.viewpanel.getViewport('3D'); vp.projection = 'Parallel'; vp.setAngles( 90 - (Math.asin(Math.tan(30 * Math.PI/180)) * 180/Math.PI), 315 );">View1</moi:CommandButton></td>
<td><moi:CommandButton icon="SetView2.png" onclick="script:var vp = moi.ui.mainWindow.viewpanel.getViewport('3D'); vp.projection = 'Parallel'; vp.setAngles( 90 - (Math.asin(Math.tan(30 * Math.PI/180)) * 180/Math.PI), 315 );">View2</moi:CommandButton></td>
<td><moi:CommandButton icon="SetView3.png" onclick="script:var vp = moi.ui.mainWindow.viewpanel.getViewport('3D'); vp.projection = 'Parallel'; vp.setAngles( 90 - (Math.asin(Math.tan(30 * Math.PI/180)) * 180/Math.PI), 315 );">View3</moi:CommandButton></td>
<td><moi:CommandButton icon="SetView4.png" onclick="script:var vp = moi.ui.mainWindow.viewpanel.getViewport('3D'); vp.projection = 'Parallel'; vp.setAngles( 90 - (Math.asin(Math.tan(30 * Math.PI/180)) * 180/Math.PI), 315 );">View4</moi:CommandButton></td>
</tr>
<!-- new stuff end -->
</table>
</div>
And also you'd need to add new images SetView1.png - SetView2.png in the icons folder if you want icons to show up there.
