>>>I'm looking for some software which will allow me to emboss or engrave an imported picture and text onto a small piece of jewellery.
Moi does not have tools for embossing a picture, but there is a free program called ZSurf which has been around for many years and might help you if Moi is your only nurbs modeler. The nurbs surface quality with ZSurf may not be suitable for some things. Rhino has better tools for this.
>>>But seems at the end of the Moi process you must export in OBJ / STL format...for some 3D Print or other real production!"
>>>Reply: Do most companies with wax printing machines accept OBJ & STL formats? Do casting shops also normally accept OBJ & STL formats?
>>>PS. I've seen plastic printed 3d parts which have a terrible surface finish. Can I expect precision waxes with .OBJ or .STL unlike 3d printed plastics?
This really depends on the manufacturing methods. If producing a die for coining/stamping, a nurbs file will typically be required.
Many people print waxes from STL files, though I don't have experience with it myself. The quality/resolution of the print is dependent on the printer and if you need higher quality and a wax print, a service with high end printer would be needed.
