A free subd to NURBS solution
 1-2  3-22  23-42  43-48
yes, because it requires to import in VRML 1 and the IGES export is not
compatible with MoI, hence the usage of FreeCAD, to get the model
into MoI.
Best regards
8667.4
Darn, no Mac OS version of Freeship. I could very much use this tool in my workflow.
Stefan, I thought you're a Mac user like me. Did you run this on a Windows PC, or am I wrong about a missing Mac OS version?
Anyway, thanks for the tip.
— Metin
metinseven.com — visualization • illustration • animation • 3D (print) design
8667.5
it's possible to translate ".obj" to ".wrl 1" only with Freecad.
Open ".obj" mesh in Freecad into Mesh workbench, select mesh and save to "#Inventor V2.1 ascii".
Open file "#Inventor V2.1 ascii" with notepad or other and change the header from "#Inventor V2.1 ascii" by "#VRML V1.0 ascii".
Open file .wrl 1 with FreeShip.
Enjoy
Hi Metin,
yes i'm a Mac user, but i have also a Windows/Linux Notebook.
But i quickly tested FreeShip under Wine and compiled
the mesh converter under OS X. When running FreeShip
under Wine the top graphics? buttons are black, but one
can still convert via the menus.
P.S. don't expect to much from the converted NURBS models...
I only wanted to show a possible solution for Programmers
like Michael and Max etc. to maybe get an idea of how this
is done with FreeShip, because it's OpenSource.
Best regards
8667.7 In reply to 8667.6
Hi Stefan
Unfortunately, this method doesn't support surfaces with extraordinary vertices. Using FreeShip you can't create nurbs surfaces with smooth transitions across edges.
Hi Max,
thanks for looking at it and explaining to us!
Best regards
8667.9
@ Stefan: Thanks for the info. I guess I'll stick to Max's subdiv tools for MoI.
@ Max / Michael: If you could build something like this for MoI, I'd gladly pay an extra sum for it — http://masterviacad.com/powerpackoverview/PowerPackPro/page36/page36.html
Here's a video:
http://www.csi-concepts.com/Demo/videos/objToSTEP.mp4
The main difference with Max's current subdiv tools is that not every quad polygon is converted into a NURBS patch, but the patches are generated based on curvature and detail level, resulting in relatively lightweight, uncluttered solids. T-Splines works that way as well.
— Metin
Message 8667.10 deleted 5 Nov 2019 by STEFAN
Hi Metin,
i did a test with Max's subd script and the merge command in other software. I could bring down
the file size from 10 MB to 5,7 MB. Now i must find a way to replace the 3 and 5 edges pole areas,
because merge does not work well with them. If we had a least something like merge in MoI then
we would have a good start with MoI and Max's subd script, i would say. This is of course a time
consuming process, but IHMO worth to explore more.
EDITED: 5 Nov 2019 by STEFAN
8667.12 In reply to 8667.11
Hi Stefan,
Interesting!
A few questions:
1: How did you get the nice all-quad topology on the Stanford bunny?
2: Which tool did you use for the merge command?
Metin
— Metin
Hi Metin,
the quad mesh is auto retopo from 3DCoat or was it ZBrush (trial) ZRemesher,
i did years ago. Can't remember wich one i used...
The merge command i used is from ArtForm Pro 4.0 NURBS Modeler module.
But i think others like Rhino etc. have a merge command too.
8667.14 In reply to 8667.13
Thanks Stefan!
Have a nice Sunday,
— Metin
You're welcome Metin.
Have a nice Sunday too!
Best regards
8667.16 In reply to 8667.15
I really hope/pray Max will find the time and will to work on the surface simplification from his amazing subdiv script. The work he did on the surface quality was (is) amazing !
Maybe it could even become a native MoI function ?
8667.17 In reply to 8667.16
Hi PaQ.
@You : "...Maybe it could even become a native MoI function ?..."
You hit the crux of the matter :)
We all know that Michael is super super busy right now, but it could be amazing if he could bring the excellent job that Max did with subDiv tools,
into the "core" of Moi (doing a translation the Max's JS code into the native compiled language with which Moi was written)
I think, and I'm sure I'm not the only one who thinks so, that Max's subDiv code "deserve" to be stable part of Moi's core :)
Ciao!
8667.18 In reply to 8667.17
I was under the impression that there still some remaining issues about surface continuity at extraordinary vertices. Is that not the case anymore?
8667.19 In reply to 8667.18
@You ".. remaining issues about surface continuity at extraordinary vertices. Is that not the case anymore?"
Well...Maybe you're right but for what I've tested so far I didn't see any issues lately. But I'm not the best person to check this kind of "math" things.
Maybe it's a better idea to ask Max or other "math" guys here :)
Thanks.
8667.20 In reply to 8667.19
Hi Marco,
Could you post a couple of the tests?
8667.21 In reply to 8667.20
@You : "...Could you post a couple of the tests?..."
Hmm...nothing serious model right now....only some old practicing but I have to search and I will post some 3dm file.
Maybe if you ask PaQ you will be provided with much more "heavy-duty" and reliable stuff :)
8667.22 In reply to 8667.20
Michael please try this and see if you see something wrong with the "subDiv" elaboration.
I've made with V3. It's a very simple use-case.
The red mark id where I think there's some strange "flow" but i don't know. Please check the entire model if you can.
Hope this can help :) This is the best I can do right now.
This is the 3dm file : http://take.ms/rhLTD
Ciao!
Show messages:  1-2  3-22  23-42  43-48
