Lots of unkown
 1-20  …  321-340  341-360  361-372
8665.361 In reply to 8665.360
Hi Tudor, you can capture a direction with a construction line and relocate it to the rotation center, then use snaps.
Here's a demonstration:
8665.362
thanks !
- Tudor -
8665.363
using this script
moi.geometryDatabase.deselectAll();
var a = moi.command.lastCommandRevisionStart;
var b = moi.command.lastCommandRevisionEnd;
var objects = moi.geometryDatabase.getObjects();
for ( var i = 0; i < objects.length; ++i ) {
var obj = objects.item(i);
if ( obj.databaseRevision> a && obj.databaseRevision <= b ) obj.selected = true; }
akka: LastCreated Object/objects -> usefull to control arrays or booleans/new geometry/curves so on
& i have some troubles
1. If I'll move an object, scale, rotate - it will count as last object, not new one created(let's say I've created a circle before - and script will record last object as LastCreated)
2. after creation if i'll cancel next operation, it wount count as last created (ex: created circle, try to move, didn't like, cancel - Last created won't count any more, history gone)
good addition will be -> undo saves last created tree* -> after 10 creation & 6 undos, will selet '4th created
as i see this should be ~ history records on new created objects, correct me if it's not designed application
- Tudor -
8665.364 In reply to 8665.363
Hi Tudor,
Yes, this is the intended behavior. When you move, scale, or rotate an object the original object is deleted and a new one is created.
Yes this is also how it is intended to work. The "last created" information that you are gathering is what was created by the last command that was run.
If you run a command and then cancel it that was the last run command and it didn't create anything, so asking for what was created by the last run command should return nothing in this situation.
If those are not doing what you need then you'll need some other mechanism to do it, these are working as they are supposed to.
8665.365
in case like this where are 2 frames of curves - can't fillet the corners (orange/green, orange/blue)
defaults - i think that it should work like blend
- Tudor -
Size: 143.1 KB, Downloaded: 24 times, Dimensions: 936x884px
8665.366 In reply to 8665.365
Hi Tudor, can you please post the .3dm model file with that geometry in it?
8665.367 In reply to 8665.366
out of space, expand my inbox )))
https://easyupload.io/6wcc94
orange/greeen - for blend
orange/blue for fillet
- Tudor -
8665.368 In reply to 8665.367
Hi Tudor, thanks for posting the file. I was hoping that would help me understand what you are asking about but I'm afraid that I still don't understand.
Are you trying to fillet curves instead of edges?
Not understanding this either, do you mean you've already done a blend between orange and green and a fillet between orange and blue?
Sorry I'm not getting it, - Michael
8665.369 In reply to 8665.368
so fillet i consider ~ a corner turn to rounded curvature with a radius
same principle want to be from blue to orange (file I've posted I've cut a part from curve (orange green) for a blend) that i'd consider as a fillet
moi doesn't have any implementation for corner blend radius -> aka fillet
https://easyupload.io/22suev explained in moi
EDITED: 20 Mar 2022 by CEMORTAN_TUDOR
8665.370 In reply to 8665.369
Hi Tudor, for curve filleting the curve segments to be filleted need to be coplanar.
That's both a limit in the geometry library and also just in general on non-coplanar setups there often won't be a spot where an arc of the given radius exists that is tangent to both curves.
8665.371 In reply to 8665.370
either in fillet tab (extra option for non-coplanar) or in blend tab with a corner selected (will act like fillet - thats why i'm more towards option in fillet tab) , both doing same thing, cut a distance and make blend together
the way i'm imagining cutting is a sphere growing radius from corner introduced by user, where sphere intersects with lines - make a cut & blend after, if growing sphere(radius) meets 3'd intersection point, algorithm fails
ofc if wont be fillet radius, but calculated radius (technically not part of fillet)
8665.372 In reply to 8665.371
Hi Tudor, yes the problem is that if you cut something by intersection with a sphere then if you try to put in a circular arc segment between the cut pieces the arc will not be tangent to both cut ends.
Show messages:  1-20  …  301-320  321-340  341-360  361-372
