First question
All  1-2  3-5
8638.3 In reply to 8638.1
Hi Salvador,
If your points are in a simple file, you could use the ImportPointFile script:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4381.7
The point file could also be made by yourself.
8638.4
Thanks for the responses.
Michael,
Just tested the point move procedure. It works fine, but should be more friendly. :)
Yes, it seems ODPasteFromExternal and ODPasteFromExternal need to be runned as admin, I wonder how to fix this.
bemfarmer,
I normally import/export meshes, seems to work fine, but you cannot (or I don't know how) change tesselation options.
Regards!
EDITED: 22 Oct 2017 by ASTICLES
8638.5 In reply to 8638.4
Hi Salvador,
I think it's because as part of its processing it writes an .obj file in the MoI commands sub-folder. The problem with that is that it's underneath the "Program Files" directory and as a security measure Windows will deny write access to that directory for programs running at the default privilege level.
The fix would be to modify the plug-in to write the .obj file to the temp folder instead, but also running MoI with elevated privileges (using "Run as administrator") should also work.
Show messages: All  1-2  3-5
