Sweep ellipse
All  1-4  5-7
8633.5 In reply to 8633.3
Modified walls:
Sweep Red obj with green rails.
Leaves a hole in bottom.
- B
8633.6 In reply to 8633.3
Hi Don, so yeah the source of your original problem is that one rail sweep rotates your profile curve to make it perpendicular to the rail tangent as it progresses along the rail.
But if your profile sticks out a further distance than the radius of the bend that will produce overlaps and bunching like this:
So you need instead something that goes like this:
Either two rail sweep like Brian has above or Rail Revolve can produce that type of thing.
8633.7 In reply to 8633.6
Thanks all. Rail revolve did the job!
Show messages: All  1-4  5-7
