Cross Section script or node
 1-12  13-21
8626.13 In reply to 8626.12
Hello Al,
I saw you have already used the bounding box. That's good!
Have a nice Weekend
Karsten
8626.14 In reply to 8626.12
Hi AL!
Thanks a lot for sharing.
Very cool stuff!
Bounding box is very useful!
Ciao.
8626.15 In reply to 8626.2
Hi Karsten,
thanks for very useful script. I have a problem with nodeditor probably, because if I start latest (v. 0.97) nodeeditor which I extracted after a long time into nodeeditor folder and load the node, so SAVE, APPLY, RUN and STEP buttons become gray and I cannot find out the reason of such behaviour.
Thank ýou for any help.
Mik
8626.16 In reply to 8626.15
Hi Mik.
I've already solved the same issue.
Get this zip archive : http://take.ms/ayOez
unzip it and copy the whole content into "C:\Program Files (x86)\MoI 3.0\ui\nodeeditor.v.0.97.2017.10.05\nodes\extensions"
or wherever you have the 0.97 version of NE.
You should get this content :
Also ensure that the very last lines of JS code into "index.html" file of 0.97 NE are these :
loadScripts('core','lang, compatibility, colors, geometry, main, editor');
loadScripts('nodes','macros, basic, logic, points, curves, solids, construct, transform, objects, interface');
loadScripts('nodes/extensions/libs','*');
loadScripts('nodes/extensions','*');
loadScripts('core','init, ext.*');
After that you should run all latest nodes without issues.
I solved in this way.
8626.17 In reply to 8626.16
Hi Marco,
this is it! It works perfectly now.
Thanks a lot.
Ciao
M
Why not post the entiere node Editor pakage with the new node ?
I suppose that a Zip file of it takes 2 seconds
It's not ecologic but that avoid any headache of version for the user! :)
If user is interested by the result he copies the .nod in its repository of nodes!
8626.19 In reply to 8626.18
Hi Pilou.
@You : "...It's not ecologic but that avoid any headache of version for the user! :)..."
LOL LOL LOL :)
Want to have fun ? Read all the posts I wrote about this argument (keep things organized, repository, versioning..)
I feel like a voice in the wilderness :)
But...no problem!
I have decided to take it easy ;)
Bye.
8626.20 In reply to 8626.19
You are not alone in the space! :)
8626.21 In reply to 8626.20
Cheers!
Show messages:  1-12  13-21
