Script reverse view problem
All  1-2  3-4
8625.3 In reply to 8625.1
Hi Benji,
this script reverts view under a mouse cursor
script:var viewport = moi.ui.getViewportUnderMouse(); viewport.viewpanel.reverseView(viewport.name);
8625.4 In reply to 8625.1
Hi Benji, the default name for that view is 'right', and viewpanel.mode is meant to control which of the bottom 5 tabs are active, it returns one of 'split', '3d', 'top', 'front', or 'right'. So for your script there you'd need to put in 'right' instead of 'left', like this:
script:if ( moi.ui.mainWindow.viewpanel.mode != 'right' ) { moi.ui.mainWindow.viewpanel.mode = 'right' } else { moi.ui.mainWindow.viewpanel.reverseView( 'right' ) };
Show messages: All  1-2  3-4
