Script reverse view problem
8625.1
Hi all
I have trouble with the script below
script:if ( moi.ui.mainWindow.viewpanel.mode != 'left' ) { moi.ui.mainWindow.viewpanel.mode = 'left' } else { moi.ui.mainWindow.viewpanel.reverseView( 'left' ) };
it works for "top" and "fornt" but not for left/right view.
Has anyone an idea what's the problem
Best Benji
8625.2 In reply to 8625.1
Hi Benji
I always wonder where a script writer finds their code?
Must be in the code for the view buttons.
.mode seems to be left out?
8625.3 In reply to 8625.1
Hi Benji,
this script reverts view under a mouse cursor
script:var viewport = moi.ui.getViewportUnderMouse(); viewport.viewpanel.reverseView(viewport.name);
8625.4 In reply to 8625.1
Hi Benji, the default name for that view is 'right', and viewpanel.mode is meant to control which of the bottom 5 tabs are active, it returns one of 'split', '3d', 'top', 'front', or 'right'. So for your script there you'd need to put in 'right' instead of 'left', like this:
script:if ( moi.ui.mainWindow.viewpanel.mode != 'right' ) { moi.ui.mainWindow.viewpanel.mode = 'right' } else { moi.ui.mainWindow.viewpanel.reverseView( 'right' ) };
