Vertex colours?
 1-12  13-32  33-35
8623.33 In reply to 8623.30
> So the question is, can MoI geometry database contain colour information for the vertices, which
> could be exported in some format?
Currently the MoI geometry database does not have any color information associated with a vertex. It does have style colors that you can set on an edge, but an edge is not the same as a vertex, an edge is something that goes between vertices.
Here's an example:
That's got 5 different colored edges but they all share the same one vertex at the top. So it's not a match to try to use edge colors as vertex colors, which of the 5 edge colors would you pick for the one vertex?
8623.34 In reply to 8623.33
Thanks to Michael and everyone for the explanations.
8623.35
Interesting thread!
Regarding formats supporting vertex colors: I usually use FBX to transfer vertex colors from Blender into ZBrush. Vice versa I export as VRML from ZBrush to have polypaint exported as vertex colors, but there's also a PLY zplugin for ZBrush.
A remark for those of you who are also using Blender and ZBrush: ZBrush uses a different vertex color approach than Blender. In Blender you can fill faces with a sharp border in the vertex colors, in ZBrush there's always a color blend into neighboring polygons when you fill a face.
— Metin
Show messages:  1-12  13-32  33-35
