DXF Splines => AutoCad => DXF
All  1-3  4-5
8606.4 In reply to 8606.3
You can try Fusion 360 as converter format files! ;)
8606.5
Hi all,
I send files to a laser cutter that can cant use splines I use the RHINO convert to ARCS you can specify the resolution much better than converting to polylines so you dont get stepping - not sure is this command exists in AUTOCAD offerings.
A Spline to ARC converter in MOI would be a fantastic addon.
Show messages: All  1-3  4-5
