Creat a Construction Line
8596.1
I need script Creat a Construction Line:
var cline = moi.command.createFactory( 'construction line' );
is not work, How do is?
8596.2 In reply to 8596.1
Hi Kondou
The constructionline3 script is here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1029.25
Place the .js and .htm files in the MoICommand folder.
Make a shortcut key. Mine uses the C key, and ConstructionLine as the command.
(I use CustomUI also, so my file name has an underline in front of it _ConstructLine
8596.3 In reply to 8596.1
Hi Kondou, sorry there isn't currently any way set up to create a construction line purely programmatically, you have to be in a pointpicker and do a drag with the mouse to do it currently. I can add a programmatic way to do it in v4, please remind me about it again once v4 betas are going.
