High Sierra maCOS 10.13
 1-11  12-21
8592.12 In reply to 8592.11
Hi Etro,
> ( I read long time ago that there was something to erase somewhere to refresh
> that, but can't remember what. )
Check if there are any old preference files that have accumulated, see here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6339.2
-> to Mickaël, Do you have any date estimation for a native OSX working release ?
Whenever I make a guess it's always been wrong, but currently I'd like to have the first beta release out by the end of this month.
8592.13 In reply to 8592.12
The end of this month would be great. I really hope so!
Have a nice weekend y'all,
— Metin
metinseven.com — visualization • illustration • animation • 3D (print) design
8592.14 In reply to 8592.4
You are a star Michael! Your instructions fixed the issue for me as well. Thank you very much!
8592.15 In reply to 8592.14
You're welcome Kroete, I'm glad that fixed it for you. Please let me know if you see any other problems running on High Sierra - if nothing else needs fixing to run there I'll make a new 3.2 release with this setting changed in it by default.
8592.16
it's working now after I unchecked the box in Wineskin !!!! thank you !!!
8592.17 In reply to 8592.16
Hi everyone,
First time caller here, I just installed the 10.13.2 Beta2 (because I enjoy frustration) and just a heads up that the Wineskin auto detect GPU checkbox fix no longer allows MoI to boot.
I know that there's a plan to release an OSX native version before too long, but between now and then, folks should know that updating to 10.13 breaks MoI.
Thank you for your time.
-kirk
8592.18 In reply to 8592.17
Hi kirk, well that's a bummer but thanks for reporting it... Maybe it's from something that they'll fix before coming out of beta. I just updated the MoI mac version to a 3.2 release which has the auto detect GPU option off by default now. The first beta of MoI v4 that has a native Mac build and doesn't use Wineskin anymore is just a couple days away.
8592.19
Thank you Michael, it works :)
8592.20
Upgrading my OS to high sierra, I had the same problem than JAVIER.
It was fixed with you wineskin instructions: Thank you !
Then I read about the V3.2. I downloaded it and get an error message trying to open it:
" ERROR ! cannot write to info.plist, there are permission problems or you are on a read-only volume. This cannot run from within a read-only dmg file "
- Are there in V3.2 other improvement than the automated wineskin fix ? If not, then I'm fine with the V3.1 fixed with your instructions.
If yes, do you have any advice to get rid of the error message above ?
- After V3,2, I downloaded the V4 beta and for now it's delightful :)
I plan to upgrade from V3 to V4.
Regarding price, will the V4 be cheaper for V3 owners as it was for V2 owners upgrading to V3 ?
Thank you !
8592.21 In reply to 8592.20
Hi Elfe,
This is due to a new security mechanism in recent OS versions that makes downloaded app bundles read only if they are run directly from the Downloads folder.
You can avoid it by moving the newly downloaded app into the /Applications folder instead of running it directly from Downloads.
MoI v4 without Wineskin won't need to modify its own info.plist file anymore so it won't happen anymore with v4.
Nope, no other changes than that in v3.2 .
It will be the same upgrade price as V2 to V3.
Thanks, - Michael
Show messages:  1-11  12-21
