Odd behavior - MoI dropping or losing focus
All  1-2  3-11
Battery in cordless keyboard or mouse?
8578.4
I use a corded mouse.
8578.5 In reply to 8578.4
Hi Mark, if you happen to have another mouse around you might try swapping it for your current one and see if that does anything.
Also do you have any kind of helper programs running that have anything to do with the mouse or window handling?
8578.6
Sorry to take so long to follow up on this. I asked the question, then had a string of personal biz to deal with that kept me away from MoI time for a bit.
I'm using a basic, wired, Logitech wheel mouse. The only mouse driver is the Apple driver that comes with OS 10.12.6. The only suspicious thing I noticed in my control panel was a legacy driver for a Griffin iMate that I used on an earlier system to provide ADB access via the USB port. These things follow from system to system via the "migration" helper. It seemed to be inactive, but I've removed it now. Still seeing the behavior but I have yet to reboot. Will do so now and report back in a bit.
8578.7
Reboot after removing the iMate driver did not solve it.
Then I switched away from my wired mouse to the Apple wireless mouse than came with the Mac. Same problem.
A further data point: When I select an object to export, the dialog that comes up has the file named highlighted so you can begin typing the name of the exported file. This highlighting lasts from a second to a few seconds, but always "goes gray" as the attention of the program is drawn away. This occurs whether I have started to type, or just sat motionless after invoking export. It's as if the dialog box is suddenly "in the background."
None of these behaviors happens outside of MoI.
Curiouser and curiouser...
Does unplugging the internet make any difference?
With Windows 7 IE, at 35 mbps, I've noticed that there seems to be an increasing amount of advertising popping up all over the internet pages,
slowing internet response to a crawl at times.
(But this is not a MoI problem.)
8578.9 In reply to 8578.7
Hi Mark, sorry unfortunately I can't think of anything else to try with the current version. Hopefully v4 will solve this problem, the v4 Mac version has been rewritten to use a Mac native compile and won't use the "Wineskin" mechanism anymore. It's probably some quirk with Wineskin/XQuartz that is causing the problem would be my best current guess.
8578.10 In reply to 8578.9
Hi Michael, looking at this thread I think that I had a similar issue a while ago. I can't remember exactly what I had done but essentially I had added a shortcut key into MoI that also corresponded to a mac shortcut! Therefore everytime I hit the shortcut key it did not do what I wanted in MoI, but went to somewhere else entirely....
-James Elliott
www.jameselliott.co.uk
8578.11 In reply to 8578.9
Thanks for trying, Michael.
If I stumble on to something in the mean time, I'll post it here. Otherwise, I'll hang in there for the V.4 upgrade.
Show messages: All  1-2  3-11
