Script to load image
All  1-4  5-9
8571.5 In reply to 8571.1
Hi track, I think it should be possible to do a scripted load of background images, but like Brian writes above it would also need to decide the placement of the image - what plane it's on and its bottom left and top right corners. How would you want the script to handle those parts?
8571.6 In reply to 8571.5
I succeeded to place an image in a given position in 3D with the property frame of the image object.
I will look at the script mentioned above
8571.7 In reply to 8571.6
Hi track, the function AddImage() in commands\Image.js is how MoI's image command creates new images. But it's a little complicated since all the UI and pointpicker bindings and such are in there as well.
Here's a streamlined example that just uses some fixed parameters:
    var filename = 'c:\\img\\test.jpg';
    var baseframe = moi.vectorMath.createTopFrame();
    var cornerpt = moi.vectorMath.createPoint(20,20,0);
    var factory = moi.command.createFactory( 'backgroundimage' );
    // background image factory has 3 inputs:
    // 0 : String - FileName
    // 1 : CoordinateFrame - Plane that gives orientation of bottom-left corner of image
    // 2 : Point - upper-right corner point.
    factory.setInput( 0, filename );
    factory.setInput( 1, baseframe );
    factory.setInput( 2, cornerpt );
    factory.commit();
Hope that helps!
Message 8571.8 deleted 1 Sep 2017 by BEMFARMER
8571.9 In reply to 8571.7
It works
Show messages: All  1-4  5-9
