Torus cut by Toroidal Helices
8567.1
Hi.
I want to cut a Torus (Ring) by a set of two Toroidal Helices to get two
single UNSEGMENTED surfaces.
Problem is when I trim the torus with the Helices the sufrfaces are
divided in segments.
Is there a way to trim in way to get a surface which is not split into segments ?
(image attached showing segments)
8567.2 In reply to 8567.1
I think not.
But just turn off edges under Types.
Join the segments.
8567.3
Thanks Brian.
I now used another way to get unsegmented surface than trimming byusing the toroidal helices as sweeps.
So segmented surfaces after trimming cabt be avoided at all ?
8567.4 In reply to 8567.3
I'd rely on Michaels response.
I think that since curves have start/end points, surfaces of revolution end up with a seam/edge somewhere...(?)
8567.5 In reply to 8567.1
Hi Tom,
Well when you have a closed surface it's going to have a "seam edge" and if you do a trim that crosses the seam edge it will form 2 faces like this:
The only way to avoid that is to not do a trim that crosses a seam, for example with the cylinder above you could rotate it around the cylinder's axis direction so that the trim was not going through the seam. So you'd do trim in a few different passes with different seam configurations rather than just one single trim all at once to avoid generating multiple faces.
8567.6 In reply to 8567.5
Very helpful information - thank you Michael !
