Setting camera from 3D scanner
All  1-3  4-13
8566.4 In reply to 8566.1
Hi track,
Do you have a link to the mathematics, the matrix, and the scanner setup?
R = rotation matrix? Is the camera or the target rotating?
P = a point?
T = a translation, or movement of the camera?
8566.5 In reply to 8566.3
Hi track,
Isn't the left/right angle = field of view angle (x2?).
The other two look like they could be calculated by doing some trigonometry math?
Can you better describe the terms and the matrix, and the camera/laser/target setup, or do you have a link with pictures?
8566.6 In reply to 8566.5
I know how to compute the field of view from the intrinsic parameters of the camera.
I know:
1) How to compute and set the eye position from my (R, T) matrix
2) How to compute and set the lookat position from my (R,T) matrix
3) How to compute and set the field of view from the internal matrix K
In a 3D scanner, the application reconstructs a 3D model and computes the position/orientation of each camera (R, T).
For each point of the 3D model X , we have the following transformations (using matlab notation):
(u, v, w)' = K * (R * X + T)
with K = [ fx 0 cx; 0 fy cy; 0 0 1]
R = [rx; ry; rz]
and T
fx, fy are focal length
cx, cy principal point (the centre of projection)
R rotation matrix, T translation vector that map points in 3D world in the camera space.
u, v projection in the image
From this equation, it is easy to see that the position of the camera expressed in 3D world is -R'*T
The viewing direction expressed in the 3D world is rz, the "up" vector is ry and the "right" vector is rx.
Today in Moi, I can set the position, the target and the field of view. But I don't know how to handle the leftRightAngle, upDownAngle and tiltAngle to get the same orientation.
8566.7 In reply to 8566.6
I need more study and information.
[rx, ry, rz] is "arbitrary rotation axis," not a rotation matrix, but [Rx] [Ry] and [Rz] can be individual 3x3 rotation matrices.
So the camera rotates left to right, and tilts up and down, and could also roll, and also Translate in 3d space.
The laser is rigidly mounted to the camera at some distance D from the camera?
The target sits at say the origin.
This link has pitch and roll trig:
https://pdfs.semanticscholar.org/3046/e4b57081ce9fd51b6a96012219f454ac3e88.pdf
EDITED: 29 Aug 2017 by BEMFARMER
8566.8 In reply to 8566.3
Hi track,
> I already saw that I can set the eye and lookat position with this script.
> But I don't know how to set the leftRightAngle, upDownAngle and tiltAngle to get the correct orientation with the matrix R,T
You wouldn't set leftRightAngle and upDownAngle if you're setting the eye and lookat position already. The leftRightAngle and upDownAngle are basically just a way to use sphereical coordinates to set the viewing direction, you would use one of those methods or the other to define the camera direction, not both.
But the eye and lookat positions will only define a viewing direction and not a "roll" (https://en.wikipedia.org/wiki/Aircraft_principal_axes) around that direction, that is what tiltAngle can be used to set though.
8566.9 In reply to 8566.6
Hi track,
So hopefully this is correct, I'm not thoroughly double checking it at the moment, but once you have set the position and target in MoI the viewing direction should match your rz and that also means you don't want to mess with the leftRightAngle and upDownAngle after that since they are alternate ways of setting the viewing direction.
Then tiltAngle will control the "up" direction's rotation around the view direction with respect to the world z axis direction.
The way the tilt angle is calculated is like this:
TempRight = CrossProduct( ViewDir, WorldZAxis )
if (TempRight.isDegenerate() )
TempRight = CrossProduct( ViewDir, WorldYAxis )
TempRight.Normalize()
NoTiltUpDir = CrossProduct( TempRight, ViewDir ).Normalize();
That's what will be the view's up direction for a "tiltAngle" of 0, you'd need to measure the angle between your view's up direction and that to get the angle to set to make them match.
Hope that helps!
8566.10 In reply to 8566.7
[rx; ry; rz] is a general rotation matrix. I'm using matlab notation
rx is the first row of my rotation matrix.
ry is the second row of my rotation matrix
ry is the third row of my rotation matrix
In my scanner there is no laser
8566.11 In reply to 8566.9
Thanks this is what I was looking for.
8566.12 In reply to 8566.10
This link shows Matlab notation which appears to be like rx, ry, rz, as far as I can tell.
https://math.stackexchange.com/questions/219864/matlab-function-rotation-matrix
google search of "matlab rotation matrix 3d" brings up all sorts of good information and code, but your questions were answered by Michael :-)
8566.13 In reply to 8566.12
Your link is about contructing a rotation matrix along a given axis and with a given angle.
It is a general formula to build a rotation matrix
In my case, rx, ry and rz are three 3D vectors.
They are the rows of my rotation matrix.
Michael answered by question.
Show messages: All  1-3  4-13
