Car Modeling in MoI(Two ways to get seamless surfaces
All  1-14  15-19
Sems CMorph by Max Smirnov inside the car's toolbox can be useful in some cases ?
http://moi3d.com/forum/index.php?webtag=MOI&msg=6373.1
You can input number of curves between Start End!
For multiple profils just repeat the process like here :)
LineWeb also for create some patches surfaces between curves?
http://moi3d.com/forum/index.php?webtag=MOI&msg=3666.1
You can input number of links...
EDITED: 24 Aug 2017 by PILOU
8559.16
Interesting, but when you make first Network patches, you can see the light flow on surface better.
I need a script, than can analyse the isospline that lays the Isocurves automaticly on the Isocurves of the neighbar patch, but I think it's very complex.
another script idea is maybe, if you could pin or snap automaticly the polygon vertices points temporary on the (red) controlsplines, after the retopo work, than it would be posible to control the meshflow better.
or
and my second idea is a kind poly UV iso spline (U=green + V=orange) loop selection script, for later clean up the patches, at now I must select all edges manually to make a Network
And there is a before/after shot
to this
8559.17
OK, a patch cleanup is with Fusion 360 the easy way:
-Export in Moi to obj:
-Open Obj in Fusion
-Convert Quad to T-Splines
-Convert T-Splines to BRep
-Export in Fusion to Iges
Open in MoI
Clean.
8559.18 In reply to 8559.17
<< a patch cleanup is with Fusion 360 the easy way:
...TSplines
A patch process can be! :)
Line Web (Lines, Polylines or Curves) and / or CMorph
Trim All
ReconstructCuves (2 points or more following wished)
EDITED: 26 Aug 2017 by PILOU
Show messages: All  1-14  15-19
