Remove Duplicates
8551.1
I was wondering if it is normal that when using the script "Remove Duplicates" it only works for Lines-Curves, etc.?
Apparently it does not apply to points. Simple test is multiple point duplicated on top of each other. When I do this nothing happens.
William
8551.2 In reply to 8551.1
I have another command called RemoveDupPts, .js and .html, which is a slight variation, incorporating objectpicker.allowPointObjects();,
rather than objectpicker.allowStandaloneCurves();,
But it does not work. (It must have been an experiment.) :-)
I do not see documentation on remove duplicates factory...
EDITED: 15 Aug 2017 by BEMFARMER
8551.3 In reply to 8551.1
Hi Bill sorry yes the RemoveDuplicates command currently only works on curves, not on points.
I'll see about updating it for MoI v4 so it can work on point objects as well.
8551.4
Michael,
Thanks...that would be a big help. I use point(s) for copy-paste, etc. and usually wind up with duplicates
that I really don't need.
Thanks again,
William
8551.5
Brian,
Documentation for "Remove Duplicates" is provided in MoI's Help File. Hope that is what you were looking for. I didn't mean to confuse anyone.
William
8551.6 In reply to 8551.5
Hi Bill, I've been able to tune this up for v4 so the first v4 beta should support points in RemoveDuplicates.
8551.7
Michael,
That's great. Thank you!
William
