Orient with CopyToPoints
All  1-2  3-9
8536.3 In reply to 8536.2
Hi Max.
I'm glad to hear you here again!
Did you hide under a rock or something this whole time ? :) :)
Thank you very much!!
It seems that your suggestion it's just what I was looking for.
Anyway, I will check the JS code of your scripts to learn more about Moi's Api function to call
in order to better understand the behavior of "orient" command.
Thanks again.
I hope that also Michael want spend some words to explain how to automate that very powerful command.
Have a nice day.
8536.4 In reply to 8536.3
Hi Marco,
Which one, do you mean orient?
There isn't too much to the orient factory itself, it takes 4 parameters:
0 : ObjectList - objects to transform
1 : CoordinateFrame - base frame
2 : CoordinateFrame - target frame
3 : bool - make copies
Most of the logic for the orient command is more in the orientation picker and not in the orient factory itself. It's not so easy to automate the orientation picker since it relies on snap points that are picked with the mouse.
8536.5 In reply to 8536.4
Hi Michael.
@You : "...It's not so easy to automate the orientation picker since it relies on snap points that are picked with the mouse..."
My aim is just automate the calculation of orientation on destination object.
So, is this impossible ?
I mean, given a bunch of "point" objects how can I calculate or get the "frame" that represents the default axis orientation of each point (inside a loop) ?
Thanks.
8536.6 In reply to 8536.5
Hi Marco,
Well a point object by itself doesn't have any concept of an orientation. It's just x,y,z coordinates in space, the default would just be world axis directions. But you might check out Max's scripts from here if you've got other additional information like surfaces or curves on a surface: http://moi3d.com/forum/index.php?webtag=MOI&msg=6486.1
Hi Marco.
I used Max's vSeed as follows.
Turn your edge into a curve by doing copy.
Create a 25 by 25 grid, at a spacing of 1 mm by 1mm, of vectors 1mm long, above your helix, in high z, oriented in the +z direction. Color style the vectors Red.
With no objects selected, Select the color style Blue.
Select the Red vectors, select the curve, and select the helix tube.
Run vSeed.
Apparently vSeed first creates a grid of Blue vectors, intermixed with the Red vectors, with each (undropped) Blue vector being oriented,
so that when dropped, it will be oriented normal to the helix tube at the point on the tube to which it is dropped.
A fraction of a second after the Blue vector grid is created, the Blue vectors drop down to the curve, and are normal to the helix tube.
Anyway, they appear to be normal.
I'm thinking that the blue vectors along the curve would be the targets of orient, but have not got that far, if it is possible with orient without manual picking...
EDITED: 31 Jul 2017 by BEMFARMER
8536.8 In reply to 8536.6
Hi Michael.
Thanks for the quick reply.
Ok. ASAP I'm going to study Max's code.
Have a nice day.
8536.9 In reply to 8536.7
Hi bemfarmer.
Thanks a lot for your suggestion.
ASAP I'm going to repeat your test .
Have a nice day.
Show messages: All  1-2  3-9
