Shell with variable width ?
All  1-3  4-5
8530.4 In reply to 8530.3
Thanks for posting the file. So yes I'd think your best bet would be using Flow, but your base surface there isn't just a simple full surface it's a trimmed surface and Flow only works on a full surface and will ignore the trim. So it's probably best to untrim it and then work on trimming the results later. If you had a cutting surface that you used to trim your surface maybe it would work for cutting both pieces.
So to make the variable offset in the attached file, I prepared 2 planes off to the side and used control point editing to move one point upwards. Then I untrimmed your surface (select all boundary edges and hit delete), then selected the edited plane, ran Transform > Deform > Flow and used the plane underneath as the base surface and your twisty surface as the target surface.
8530.5 In reply to 8530.4
You never stop amazing with your support - thank you Michael !
Show messages: All  1-3  4-5
